110493: <value> is not a hot spot analysis result.
The input hot spot analysis results must each contain a field named Gi_Bin that contains only integers between -3 and 3.
Feature classes created by the Hot Spot Analysis (Getis-Ord Gi*) or Optimized Hot Spot Analysis tool will contain this field with the values representing the significance level of the results for each feature.
Solution
Only use inputs that represent hot spot analysis results.
