110509: The input hot spot results must have at least 20 feature intersections.
The input hot spot result layers are intersected before analysis so that every feature in each result layer can be paired with a single feature of the other result layer. The provided layers did not have at least 20 feature intersections, which is required.
Solution
For polygon result layers, verify that there is sufficient overlap in the polygons so that there are at least 20 intersections.
For points, verify that at least 20 points in each result share the same coordinates.
For lines, verify that at least 20 lines from each result cross each other or share multiple vertices.
