110517: The following fields in the input(s) are of an unsupported type for the output workspace: <value>
Based on the listed input fields, the outputs cannot be written to the chosen workspace because the workspace does not support the necessary field types. For example, a Big Integer field cannot be written to a shapefile.
Solution
Use an output workspace that supports these field types. For example, a Big Integer field can be written to a file geodatabase.
