110532: The Upper Bound value must be greater than the Lower Bound value in <value>.
The Lower Bound value is equal to or greater than the Upper Bound value for a hyperparameter in the value table.
Solution
Provide an Upper Bound value that is greater than the Lower Bound value for each hyperparameter in the value table.
Label
Name
Range
Number of Trees
number_of_trees
An integer value greater than 1.
Maximum Tree Depth
maximum_depth
An integer value greater than or equal to 0.
Minimum Leaf Size
minimum_leaf_size
Data Available per Tree (%)
sample_size
An integer value greater than 0 and less than or equal to 100.
Number of Randomly Sampled Variables
random_variables
An integer value less than or equal to the number of explanatory variables. This includes the explanatory variables from fields, distance features, and rasters.
Learning Rate (Eta)
eta
A double value greater than 0 and less than or equal to 1.
L2 Regularization (Lambda)
reg_lambda
A double value greater than or equal to 0.
Minimum Loss Reduction for Splits (Gamma)
gamma
Maximum Number of Bins for Searching Splits
max_bins
An integer value greater than 1 or equal to 0. A value of 0 means the model will create a candidate split at every data point.
The range of valid values for each hyperparameter.
