110553: Rate Method <value> is not supported for input tables.
Tables cannot include geographic information. If the input is a table, the Locally Weighted Average, Locally Weighted Median, and Local Empirical Bayes spatial smoothing options are not available.
Solution
If the input is a table, specify Crude Rate or Global Empirical Bayes as the Rate Method parameter value. To use a spatial rate smoothing method, change the input to a shapefile or feature class.
