110620: The Power Expansion did not converge. Please check your model and spatial weights specifications.
The model failed to estimate the value of the autoregressive parameter, rho. This can occur when the spatial weights matrix does not effectively model the spatial relationships present in the data or if other model specifications do not effectively model the dependent variable.
Solution
Use other options for the Neighborhood Type or Local Weighting Scheme parameters. Alternatively, remove or include new explanatory variables that better explain the dependent variable.
