120011: This tool requires a projected coordinate system.
Tools that use spatial binning into squares or hexagons or the spatial distance Near require a projected coordinate system to correctly compute results.
Solution
If the input feature is in a geographic coordinate system, set the output coordinate system to a projected coordinate system using Environments. When you set an output coordinate system, the input will be projected to the output coordinate system before analysis is completed.
