120032: Field '<value>' if field '<value>' is set.
There must be a field name supplied for the tool to complete successfully.
Solution
Provide a field that can be used to complete analysis. For example, if you are running Create Buffers and dissolving the overlapping buffers using type Field, it is required that your specify which field to dissolve on.
