120038: One of either '<value>' or '<value>' is required.
The tool requires that one of the specified parameters must be used to complete the tool run.
Solution
Provide an input that can be used to run the tool. For example, if you are aggregating points, you must specify if you will be aggregating into polygons or bins. If you are aggregating into polygons, specify a polygon layer. If aggregating into bins, specify a bin size.
