120044: Some planar buffer results may exceed valid extent. Consider using a geodesic buffer to account for the shape of the earth.
Applying a planar buffer will not correctly buffer across the international date line. The buffer distance supplied may exceed the bounds of the planar projection, and you should consider using a geodesic buffer.
Solution
Rerun Create Buffers using a geodesic buffer distance.
