120057: The input (or coordinate system environment) must be in a projected coordinate system for binning.
Analysis requiring square or hexagon bins requires a projected coordinate system to correctly compute bins.
Solution
If your input is in a geographic coordinate system, set the output coordinate system to a projected coordinate system using the Environment settings. Inputs with an output coordinate system will first be projected to the input coordinate system, and then correctly analyzed using the projected coordinate system. Results will be stored in the coordinate system of analysis for the relational data store and in WGS84 for the spatiotemporal data store.
