120062: <value> will be limited to the output extent.
Analysis results may exceed the valid bounds of the resulting coordinate system. Only the results within the extent will be returned. If results are stored in the relational data store, this is the same coordinate system that was used for analysis. If results are stored in the spatiotemporal data store, this is extent of WGS84.
Solution
Verify that you are using a coordinate system that spans the extent of the data you are analyzing.
