120065: An error occurred while returning the result, however, the result should still be available in your contents.
There was an error reading the status of your GeoAnalytics job. Although there was an error and results will not be added to the map, it is expected that your layer will still be available in your contents in ArcGIS Enterprise.
Solution
Refresh your contents and check if the newly created layer is available.
