120112: <value> fields (plus system fields) exceeds limit of <value> for <value> data store.
The maximum number of fields have been exceeded for a result being saved to the specified data store.
Solution
The error may be solved by one of the following solutions:
If you are saving to a relational data store, try saving to a spatiotemporal data store instead. A spatiotemporal data store allows you to store more fields.
If the tool generates field statistics, ensure that you are only calculating the statistics of interest.
Delete unused fields in your dataset before running analysis.
