120123: Processing extent is null or empty.
The specified processing extent is null or empty.
Solution
Confirm that the processing extent specified contains valid values for xmin, ymin, xmax, and ymax. Ensure that the maximum values are greater than the minimum values. The processing extent is set using the Output Coordinate System environment setting.
