120144: <value> is not valid for variable <value>.
The search distance value is not valid for the variable <value>.
Solution
Set search distances to be positive, numeric values.
Set a search distance for the variable if it is required.
For example, the Distance to Nearest and Attribute of Nearest variables require a defined search distance. The Attribute Summary of Related variable does not require a defined search distance.
