120158: The following fields have not been appended: <value>.
Append layer fields will not be appended unless matched with an input layer field of the same name and type, or mapped to an input layer field using the field mapping parameter.
Solution
This is a warning and should be expected if you did not map these fields in the Append Fields or Append Expressions parameter.
