120159: The following append field does not exist in the append layer: <value>.
Append layer field names must exist to be used in field mapping.
Solution
This is a warning and should be expected if an append field entered in the Append Fields or Append Expressions parameter does not exist.
Check that there are no spelling errors for append layer field names used in the Append Fields or Append Expressions parameter.
