120169: Merge layer's time type does not match that of the input layer. Expected <value>, but got <value>.
Both layers must have the same time type.
Solution
Verify that each layer in the tool has the same time type. For example, both layers can have time with type instant. If you want to use data with different time types, you can modify the time type of the data in the portal settings so they match.
