120170: The field <value> has been assigned an operation <value> times.
The same field has been mapped more than once in the merging attributes.
Solution
Reassess the field mapping parameters that you specified to see if a single field was mapped two or more times. For example, if you had a field named inputField and specified that you wanted it deleted, as well as merged with another field called newInputField.
