120178: A field is missing in the merging attributes for <value>.
Both an input field and a merge field are required when using the match and rename methods.
Solution
When specifying the merge options, each merge choice must have one of the three merge types: Match, Remove, or Rename. Modify your inputs so that all fields in the merge field have a type.
