120180: One or more fields with matching names could not be merged because of incompatible field types. Use merging attributes to resolve the conflicts.
When merging, fields that are being matched that don't have the same field type will fail.
Solution
By default, fields with matching names are merged. If fields with the same name in the input and merge layer have different field types, the merge will fail. To fix this, determine how the fields will be matched using the merging attributes parameters to rename, remove, or match fields.
