120183: The result of your analysis did not return any features for <value>. <value> will not be created.
One of the layers in your results did not create any features, so the layer was not created.
Solution
In some cases, this may be expected, for example, if you select a process extent without any data in it, no results will be returned. If it's unexpected, review the inputs and environment settings of the tool you used.
