120221: The output template defines a geometry or time format that is not valid or not supported by the output data source.
The output template does not allow the specified geometry or time format.
Solution
Certain template file types have restrictions on the time and geometry values allowed. For example, you cannot write tables or time values as part of a date field to shapefiles. Confirm that you are using the correct template for your output.
