120224: Output template <value> is not valid.
The output template is not valid. The template must be shared with you, you must have read and write access to it, and it must contain all the required properties.
Solution
Confirm that the folder location is available and has read and write enabled. Also confirm that the output template has the following required information:
Name
Title
Format (including the type of file and extension)
