120276: Dataset <value> does not exist in the connection file <value>
The dataset cannot be found in the multifile feature connection file (.mfc).
Solution
Make sure that the dataset exists in the multifile feature connection file specified.
  • Verify the name or alias you are using is spelled correctly.
  • If the dataset has been accidentally removed from the multifile feature connection, use the Refresh Multifile Feature Connection tool to reregister the dataset.
To learn more about .mfc files and formatting, see Multifile feature connections.
