120277: Source path <value> is not valid.
The location you have specified as the source for your multifile feature connection is invalid or inaccessible.
Solution
Check that the local or network pathway is specified correctly.
Verify you have the appropriate permissions and credentials for the location specified. For example, verify you can access the folder location specified.
To learn more about supported source locations, see Multifile feature connections.
