120288: Failed to remove <value> from MFC file: <value>
The specified dataset could not be removed from the multifile feature connection (MFC).
Solution
Verify that the following are correct, and update as necessary:
  • The pathway to a MFC dataset is formatted such as c:\MyProjectFolder\MyMultifileFeatureConnection.mfc\MyDatasetName.
  • The dataset name is spelled correctly.
  • The dataset name uses the correct casing.
