120292: Big data connection dataset <value> does not exist.
The multifile feature connection (MFC) dataset provided does not exist.
Solution
The dataset specified does not exist in the multifile feature connection (MFC). Verify that the following are correct, and update as necessary:
  • The pathway to a MFC dataset should be formatted such as c:\MyProjectFolder\MyMultifileFeatureConnection.mfc\MyDatasetName .
  • The dataset name is spelled correctly.
  • The dataset name uses the correct casing.
  • If the dataset has been accidentally removed from the multifile feature connection, use the Refresh Multifile Feature Connection tool to reregister the dataset.
