120293: An error occurred trying to duplicate dataset <value>.
There was a problem duplicating the specified dataset.
Solution
Check that the following are correct:
The dataset name is spelled with the expected casing.
If the dataset has been accidentally removed from the multifile feature connection, use the Refresh Multifile Feature Connection tool to reregister the dataset.
The pathway to a MFC dataset should be formatted such as
c:\MyProjectFolder\MyBigDataConnection.mfc\MyMFCDataset.
