120296: Failed to write results to the spatiotemporal big data store.
There was a failure writing the result to the spatiotemporal big data store.
Solution
Validate the data store to verify you can write results to it. Two common causes of this issue are the following:
Your spatiotemporal data store is in read-only mode
You have too many services and need to delete some or add more machines to your spatiotemporal data store.
Optionally, set your results to write to the relational data store instead.
