120385: No direction value matching values have been provided. All input lines will be assumed to be bidirectional.
If direction value matching is not used, all lines will be used as bidirectional for analysis.
Solution
If the input line layer has a field indicating direction values, consider specifying them in the direction field matching parameter. This is not required, but results may be more accurate if specified.
