120386: Analysis requires more memory than is available.
There is not enough memory available to complete the analysis.
Solution
Review the following to improve memory usage:
Stop other processes that consume memory and are currently running on your machine. Run the analysis when more memory is available.
Set the Extent environment to analyze a smaller area of the dataset.
Use a selection, filter, or definition query on the input datasets to analyze only the features of interest.
Some tools have parameters that can be used to improve performance. For example, if the tool uses binning, consider increasing the bin size. See the tool documentation for more information.
