120387: H3 Bin generation and analysis require geometries to be in the World Geodetic System 1984 coordinate system. This transformation has been applied.
H3 binning and analysis can only be completed using the World Geodetic System 1984 (WGS84) coordinate system.
Solution
If the data is not in WGS84, it will be projected for analysis. Alternatively, use the Output Coordinate System environment and set it to WGS 1984 before running the analysis.
