120391: The input layer has fields with new data types not yet supported by GeoAnalytics: <value>
Some field types are not yet supported as input to GeoAnalytics tools. The field types will be supported in a later version.
Solution
GeoAnalytics tools do not support the following field types as input: time only, date only, and timezone offset. To run the tool, you can create a copy of the input dataset, and either delete the fields with unsupported types or calculate new text fields that contain the unsupported values represented as strings.
