130100: Number of route representations that had other geometric problems and were ignored: <value>
This is an informational message showing the number of routes that had other geometric processing issues and were not loaded.
Solution
Examine the log returned with the results of the tool to identify the problematic polylines, for example, a null geometry in the shape column. If you are not sure what caused the problem, contact Esri Technical Support.
