130182: No LRS dataset is present. Run the Modify LRS tool on the geodatabase to add the LRS dataset.
The geodatabase does not contain an LRS dataset. The existing LRS needs to be updated using the Modify LRS tool.
Solution
Consolidate all the feature classes that participate in the LRS Network into a single feature dataset. Then run the Modify LRS tool on the geodatabase to create an LRS dataset.
