130185: You have chosen to remove LRS networks that have corresponding centerline sequence records. Use the Delete Routes tool to clean your network data from the LRS, and then proceed.
Centerline sequence records associated with routes in the LRS networks need to be deleted before removing the LRS networks.
Solution
If you are removing an LRS Network that contains routes with centerline sequence records, you must delete the routes and their associations using the Delete Routes tool before you can delete the LRS Network.
