130188: Gap calibration offset is less than or equal to the m-tolerance of the network.
The gap calibration offset can be set to either zero or a value greater than the m-tolerance of the network. It cannot be less than or equal to the m-tolerance of the network
Solution
Set the gap calibration offset to a value greater than the m-tolerance of the network. If you prefer calibration values to be the same across the gaps, set the calibration offset to zero.
