130191: Number of route representations that would produce non-monotonic calibration points and were ignored: <value>
There are route representations that would have produced nonmonotonic calibration points because of their geometry, gap calibration rule, and gap calibration offset. As a result, no calibration points have been created for those route representations.
This can happen when the gap calibration rule is stepping increment and the gap calibration offset is set to a value that will result in a calibration point larger in measure than the downstream calibration point.
Solution
Change the gap calibration offset value or change the geometry to solve this problem.
