130221: Number of route representations that had less than two calibration points in a loop and will be calibrated based on direction of the centerline: <value>.
Some route representations had less than two calibration points in a loop and will be calibrated based on the centerline direction.
Solution
Examine the log returned with the tool run to find the route representations that caused the problem. If you are unable to detect the problem, contact Esri Technical Support.
