160344: The number of errors generated during the topology analysis exceeds the specified threshold.
The number of errors generated during the topology analysis exceeds the Maximum number of errors parameter value.
Solution
Increase the Maximum number of errors parameter value to allow all errors to be discovered. A parameter value of -1 or no value will allow an unbounded number of errors to be discovered.
When running the Enable Network Topology tool with the Only generate errors parameter checked, any errors discovered before the maximum number of errors threshold is reached will be updated in the dirty areas sublayer for review and correction.
