160398: The required XML element was not found.
Solution
While this error can occur, it occurs so rarely that the typical causes have not been identified so no solution is available at this time.
If you would use the feedback form to provide details about the steps you were using that led to this error, that will be helpful in identifying and providing a solution in the future.
Helpful information includes the following:
The message ID and the error or warning message
The name of the tool
The values used for the parameters
Relevant dataset details
If the tool is no longer open, you can find these details in the geoprocessing history.
Any information you can provide is appreciated. Thank you for helping to improve the error code documentation.
