160701: Create Replica failed. The replica data does not exist on the child. If using the 'Register existing data only' option, the replica data must already exist on the target and you must be connected as the data owner.
Create Replica failed. The replica data does not exist on the child. If you're using the Register existing data only option, the replica data must already exist on the target and you must be connected as the data owner.
Solution
Additional details about this error are still being collected.
If viewing the web help, use the Feedback on this topic? link below to provide details about the steps you were using that led to this error; that will be helpful in identifying and providing a solution.
Helpful information includes the following:
  • The message ID and the error or warning message
  • The name of the tool
  • The values used for the parameters
  • Relevant dataset details
If the tool is no longer open, you can find these details in the geoprocessing history.
Any information you can provide is appreciated. Thank you for helping to improve the error code documentation.
