160794: The replace command cannot be completed because the attributed relationship row's origin or destination class object does not exist. Ensure that both of the related objects are present before attempting to execute the replace command.
The replace command cannot be completed because the attributed relationship row's origin or destination class object does not exist. Ensure that both of the related objects are present before attempting to run the replace command.
Solution
Additional details about this error are still being collected.
If viewing the web help, use the Feedback on this topic? link below to provide details about the steps you were using that led to this error; that will be helpful in identifying and providing a solution.
Helpful information includes the following:
  • The message ID and the error or warning message
  • The name of the tool
  • The values used for the parameters
  • Relevant dataset details
If the tool is no longer open, you can find these details in the geoprocessing history.
Any information you can provide is appreciated. Thank you for helping to improve the error code documentation.
