160832: Utility network requires both Snapshot and Read Committed isolation settings to be enabled in SQL Server. Contact your database administrator.
The utility network requires both Snapshot and Read Committed isolation settings to be enabled in SQL Server. Contact your database administrator.
Solution
Additional details about this error are still being collected.
If viewing the web help, use the Feedback on this topic? link below to provide details about the steps you were using that led to this error; that will be helpful in identifying and providing a solution.
Helpful information includes the following:
The message ID and the error or warning message
The name of the tool
The values used for the parameters
Relevant dataset details
If the tool is no longer open, you can find these details in the geoprocessing history.
Any information you can provide is appreciated. Thank you for helping to improve the error code documentation.
