161003: Cannot compress <value>. Compression not supported on 64-bit object ID, big integer, date only, time only or timestamp offset fields.
The file geodatabase contains a feature class or table that has at least one field data type that cannot be compressed. The following field data types are not supported:
  • Object ID (64-bit)
  • Big integer (64-bit)
  • Date only
  • Time only
  • Timestamp offset
The specific feature class or table may be referenced following the error text.
Solution
The tool will compress the remaining data in the file geodatabase; however, any datasets containing unsupported field data types will not be compressed.
See Compress file geodatabase data to learn more about the items that can be compressed and those that cannot.
