161018: Named trace configuration is used by a network diagram template.
The named trace configuration you want to delete is used by a Trace rule on a diagram template.
Solution
Analyze the diagram template definitions to identify those configured with a Trace rule that uses this named trace configuration. Modify the Trace rule parameters so it no longer uses the named trace configuration you want to delete.
