180026: ArcGIS Indoors schema files are missing. Unable to create the Indoors database.
The Indoors schema .xml files could not be found.
Solution
Browse to Indoors\Schema in the ArcGIS Pro installation directory and confirm that the schema .xml files exist in the Schema folder. The following are the schema file names:
AREAS.XMLINDOORS.XMLINDOORSCONFIG.XMLNETWORK.XMLPRELIMNETWORK.XML
If files are missing, you can copy them to the Schema folder from another machine that has ArcGIS Pro installed. You can also reinstall ArcGIS Pro.
