180035: The target geodatabase already contains an Indoors dataset. Choose the Create Indoors Network option to create the Network and PrelimNetwork datasets in the target geodatabase.
You cannot run the tool when the target geodatabase contains an existing Indoors dataset unless you are creating a new Indoors network dataset.
Solution
Do one of the following to run the Create Indoors Database tool:
  • Delete the existing Indoors dataset in the target geodatabase.
  • If you have not created an Indoors network dataset, run the tool with the Create Indoors Network parameter checked. This creates an Indoors network dataset in the target geodatabase and does not affect the existing Indoors dataset.
  • Select a target geodatabase that does not contain an Indoors dataset.
